• 27.02.2026, 07:26
Winczlav
Aquasuite compatibility
Mittwoch, 30. September 2020, 07:06
Hi everybody,
I'm searching some informations about the RGB compatibility of the Aquasuite.
I'm looking for a Corsair XC7 CPU waterblock (i7-8700k) and a Corsair XG7 GPU waterblock (2080 Super).
Can I control all the RGB via the Aquasuite ?
And what about my Asus Hero X Motherboard ?
Thanks for your help.
Mittwoch, 30. September 2020, 11:26
The aquasuite can only control our own devices. The software has no access to the LEDs of other devices.
k2viper
Mittwoch, 30. September 2020, 16:17
Corsair XC7's RGB connector looks quite similar to those on Corsair RGB fans, and Corsair i-cue controller compatibility is claimed. So it should work with any Aquacomputer RGBpx controllers (in Quadro/Octo/D5NEXT/farbwerk360) through Splitty4. Although XC7 connector is 3-pin, meaning it does not have "data out" wired, so this block should only be connected as last device in any RGBpx LED chain.
And you cannot control motherboard LEDs with aquasuite or any aquacomputer devices.
