• 30.03.2026, 04:41
ScottishCaptain
Aquaduct 360XT - Sufficient cooling?
Sonntag, 27. Januar 2008, 03:11
One last question before I decide if I'm going to go with the 360 XT.
I'm planning on building a system around a 680i Black Pearl motherboard (factory installed Innovatek waterblocks), and an 8800 Ultra/768MB Black Pearl video card (also with a built-in waterblock).
The processor will be a Q6600.
Will the Aquaduct 360XT handle this massive loop? With the motherboard, just about everything has a block on it- southbridge, northbridge, VRM's, and CPU. Throw in the 8800 Ultra, and that's a fair whack of heat to dissipate.
I'm still looking to keep the system reasonably quiet when it's idling. I don't care if it's revving up under load, but I should hope the Aquaduct wouldn't sit there at 100% all the time (if it can't handle the load).
So, will it work? Or am I maxing it out?
-SC
pharao
Re: Aquaduct 360XT - Sufficient cooling?
Sonntag, 27. Januar 2008, 11:28
I'd even say an Aquaduct 240 might do it - but the AD360 will be fine.
btw: the AD 240 handles 500W, the AD360 handles 700W.
divve
Sonntag, 27. Januar 2008, 20:10
Provided you don't expect a higher range (+25%) CPU overclock it should meet the expectations you've stated.
ScottishCaptain
Montag, 28. Januar 2008, 01:24
Aha. That's what I was looking for- the maximum dissipation (watts). I'm surprised Aqua Computer doesn't have that anywhere on the product page.
I'm actually going with a dual Opteron (125W/piece) setup, and two 8800GTS's, which is still far under 700W. Gonna be one heck of a system...
Thanks!
-SC
pharao
Montag, 28. Januar 2008, 09:06
I got that Information from the - Aquaduct-Flyer unfortunately german only.
