• 21.01.2026, 13:56
kensaundm31
Mounting the D5 NEXT pump?
Sonntag, 29. November 2020, 15:13
Hi, I have decided to get the D5 NEXT instead of the EK D5 pump and I want to mount it horizontally on a horizontal 120mm fan. The mount that comes with the D5 NEXT pump seems to be only for mounting to to a vertical fan.
WIll the D5 NEXT attach without modification to this mount?
"...is a mounting adapter for installation of EK D5, DDC, SPC, and VTX pumps and pump-reservoir combo units to any 120mm fan mounting hole pattern (105mm hole spacing)."
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »kensaundm31« (29. November 2020, 15:16)
Hufeisen
Sonntag, 29. November 2020, 21:08
Probably not.
Aquacomputer has its own mounting plate, see here: https://shop.aquacomputer.de/product_inf…roducts_id=3789
