• 12.04.2026, 10:18
stan300
ULTITUBE 200 with next d5 pump "advice"
Montag, 21. Dezember 2020, 07:44
I got ULTITUBE 200 reservoir with next d5 pump and the top inline accessory..
is it ok to close the inline port that come as default with the reservoir,
and use the top inline port? does it effect the flow?
»stan300« hat folgende Datei angehängt:
  • aqua1.jpg (48,19 kB - 228 mal heruntergeladen - zuletzt: 10. April 2026, 20:14)
k2viper
Dienstag, 22. Dezember 2020, 20:28
If your ULTITUBE top cover has G1/4 port, it is totally OK to use it as inlet.
stan300
Dienstag, 22. Dezember 2020, 22:57
yes it has,i bought top inline cover accessory to replace the original one..
thank you...
