• 07.05.2026, 13:47
kbolin
AC D5 usb/aquabus not showing up as output to curve controller
Freitag, 25. Dezember 2020, 00:08
I accidently deleted my curve controller after I did new install of ver. X.31 12/15/2020
My D5 is not showing up as a option in the outputs of the curve controller .
See screen cap's attachments
Any thoughts what I did ?
»kbolin« hat folgende Dateien angehängt:
  • Capture2.JPG (89,07 kB - 77 mal heruntergeladen - zuletzt: 26. April 2026, 01:28)
  • Capture1.JPG (70,61 kB - 77 mal heruntergeladen - zuletzt: 25. April 2026, 23:16)
Freitag, 25. Dezember 2020, 01:04
Oops, my reply was to another post, but after logging in I mistakenly selected this post. :S
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »InfoSeeker« (26. Dezember 2020, 21:05)
kbolin
Freitag, 25. Dezember 2020, 01:40
Thanks . I decided to start from the top and work the problem , Looks like a simple loose cable , How many times have I been bit by the bad or loose cable .. :cursing:
Thanks for your response
