• 14.02.2026, 23:08
ratzofftoya
Pump Orientation Options
Montag, 18. Januar 2021, 13:47
Hi there,
I would like to have an Aquabus pump, which these days I suppose is only the D5 Next. Now, I don't think I can use the ULTITOP pump top because I need my outlet to be pointed down instead of up. What are my best pump top options for pointing down?
Thanks!
k2viper
Dienstag, 19. Januar 2021, 08:49
For example, EK D5 mounts are allowing to turn pump any angle, so outlet can be pointed down. But EK D5 mounts are not compatible with D5 NEXT, only with "standard" D5 without additional attach.
ratzofftoya
Dienstag, 19. Januar 2021, 09:49
Yes, hence my dilemma! Would appreciate any suggestions. :D
