• 12.04.2026, 16:23
HWiNFO
Freitag, 19. Februar 2021, 14:37
Interesting POST for those using HWiNFO.
Hopper64
Freitag, 19. Februar 2021, 17:50
Thanks for posting that.
Dienstag, 9. März 2021, 19:35
II ARROWS
Freitag, 9. April 2021, 18:03
I'm not sure it works as intended... according to the statement, I should be able to see data for 12 hours, as explained here:
Q: I'm using HWiNFO64 for personal (non-commercial) purposes together with an application pulling data from HWiNFO64 via SHM. Will I need to purchase HWiNFO64 Pro?
A: You're not required to purchase HWiNFO64 Pro. If the SHM is used for limited time periods (i.e. to watch stats in game), or if you're OK with manually enabling it after 12 hours, you can stay with the non-Pro version.
But I don't see it
II ARROWS
Freitag, 9. April 2021, 18:22
Oh, I found it... it's on the setting from the tray icon.
Kyle XY
Sonntag, 11. Dezember 2022, 15:55
Hello Sebastian,
Indeed, it's useful. I was afraid of not finding anymore HWiNFO data on Aquasuite.
:thumbup:
