• 21.02.2026, 23:29
girion
Overvolting
Sonntag, 21. Februar 2021, 19:39
Since my last upgrade and system overhaul, I have been plagued by random overvolting issues on one of my two Aquaero6LT.
System setup:
  1. Aquaero 1: 7 fans in 3 groups (2 + 2 + 3), 1 pump, 3xNoctua 12x25 and 4xNoctua NF-A14
  2. Aquaero 2: 5 fans in 4 groups (1+1+1+2), all Noctua 12x25
Both the NF-A14 fans and the pump get the issues randomly, there sem to be no problems with the 12x25s.
The fans in (bottom out) is turned off, and the pump is set to 100%. If it were just the NF-A14 fans, but when I also suddenly get issues with the pump, I get a bit bewildered. where should I even start with this issue? ?( ?( ?(
girion
Dienstag, 23. Februar 2021, 21:37
NM, seems like there were several issues at the same time: Broken pump and Aquaero at the same time!
