• 14.11.2025, 04:33
xhamster
No display on aquaero 5 pro
Freitag, 12. März 2021, 04:38
Hi, I got a aquaero 5 pro on hand recently, I use usb connector and molex all hooked on.
PC can recognize aquaero 5 pro, but there is no display at all on the screen.
I tried unscrew all standoffs and screws, directly push the display connector.
As picture shows there should no problem with connection. Can Support or anyone give some suggestion about this issue?
Some times when I re plug it it will light for 1 sec and goes all black.
»xhamster« hat folgende Datei angehängt:
  • DSC_0677 1.jpg (632,23 kB - 150 mal heruntergeladen - zuletzt: 1. Oktober 2025, 07:34)
Freitag, 12. März 2021, 09:30
Normally the display always works. How old the device?
Possibly the display is faulty.
xhamster
Freitag, 12. März 2021, 10:02
I got it from another person, So it's been used awhile. The data according to aquasuite says it's about 2 years.
Is there a way to fix it? Or it's not worth the trouble. If I want to replace it, Can I use the XT version screen?
Freitag, 12. März 2021, 10:35
no, the mounting is different.
You can try it with an replacement display. Otherwise use the devcie without the display.
