• 30.01.2026, 09:00
M3TAl
New to Aquacomputer Product Ecosystem - Need Advice
Samstag, 27. März 2021, 02:32
So I'm not very familiar at all with the Aquacomputer/Aquabus product stack. If I had dual loops and wanted to run the new High Flow 2 flow sensor on each loop what products would be needed to make that happen? I saw the QUADRO and OCTO fan controllers but they only accept a single flow sensor?
Sonntag, 28. März 2021, 05:19
Aquaero can handle two flow sensors,
Sonntag, 28. März 2021, 06:18
My personal preference would be 2 OCTOS, in addition to the two High Flow 2s you spec'd.
M3TAl
Dienstag, 30. März 2021, 01:15
Ended up buying 2x OCTO's which is really more than I wanted to spend but oh well. The flow sensors are out of stock too so got to wait for those. At least the OCTO's will do everything I need and then some.
