• 08.01.2026, 04:36
ktseymour
Fluctuating RPM's
Sonntag, 3. Februar 2008, 19:48
Hey guys, I've reading the forum for about a week now and it has helped me out allot but I don't remember seeing any posts on this topic before. I just bought the Aquastream XT Ultra and have it running with a Asus Maximus Extreme. I need to know why the RPM's fluctuate from 1448-21\2200. Is this normal? I also have the flashing red light ,but can't get AquaEro in the states as the only distributer has sold out. Could the firmware update that fixes this be why the RPM's fluctuate?
ktseymour
Re: Fluctuating RPM's
Mittwoch, 6. Februar 2008, 05:41
Are the guys at AC on vacation this week, or is this a user supported forum? I know that the pump is supposed to set frequency automatically, but this thing was released with a half-baked firmware, so you just don't know if it's working right?
gr3if
Mittwoch, 6. Februar 2008, 11:54
The Red flashing light is normal. It indicates that the pump is workin. Or is it flashing more than once a second?
About the fluctuating Rpms that could be normal.
Why dont you just connect the pump via Usb and then look up what the aquasuite gives you?
