• 22.05.2026, 10:38
cptninc
What's the best way to control RGB on 10x QL120 fans?
Mittwoch, 7. Juli 2021, 13:15
Do I really need 5x Splitty4s and 2x Farbwerk 360s, or is there a better way?
Remayz
Mittwoch, 7. Juli 2021, 20:47
given the number of LEDs in those.. seems there's not much of a choice, if you want to retain individual RGB control on each fan (no splitters).
Same struggle as with Corsair lighting node pros. Using QLs on one channel will max out the controller and render the second channel useless.
