• 03.05.2026, 22:49
CluckyTaco
Replacement Part for Ultitube Pro D5 200 Reservoir
Samstag, 10. Juli 2021, 11:48
Hi I accidentally stripped the mounting holes for the 3 screws to mount the pump/reservoir. I am unable to find the replacement part for this. I have attached the image of the part, ignore the filter I need the pump top that goes in between the pump and reservoir. Thanks in advance.
»CluckyTaco« hat folgende Datei angehängt:
Samstag, 10. Juli 2021, 18:57
CluckyTaco
Sonntag, 11. Juli 2021, 11:57
Thanks for this. It says email takes upto 4 weeks. Hopefully not in my case.
