• 11.05.2026, 10:27
defiantone07
Possible to connect and control the D5 Next into an Octo
Donnerstag, 22. Juli 2021, 07:35
Can I control the D5 next if I hook it up to the Octo in Aquasuite or does the D5 next have to be connected to my mobo. If I can from the octo how do you wire up and set up in aquasuite?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »defiantone07« (22. Juli 2021, 07:38)
Donnerstag, 22. Juli 2021, 08:08
No, you have to connect the D5 NEXT to a USB header on the motherboard, then you can configure it via Aquasuite.
