• 12.02.2026, 01:25
boSsOfDMaX
Problems after update
Sonntag, 25. Juli 2021, 22:52
Hello,
I've been struggling with a problem that I couldn't solve since yesterday. after updating i got a few errors and tried all the standard solutions but in vain. I lost OCTO and can't update, can't control fans. what if any of you have the same problem after the update, what is the solution?
Thanks in advance.
https://www.instagram.com/tv/CRwFAtWBzBm…g_web_copy_link
»boSsOfDMaX« hat folgende Dateien angehängt:
  • 1.jpg (169,83 kB - 114 mal heruntergeladen - zuletzt: 8. Februar 2026, 07:24)
  • 2.jpg (110,2 kB - 115 mal heruntergeladen - zuletzt: 20. Januar 2026, 23:27)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »boSsOfDMaX« (25. Juli 2021, 22:53)
ae111James
Sonntag, 8. August 2021, 08:27
were you able to fix your problem?
i also always had problems with my OCTO whenever i'm updating it.
For me, i always need to unplug everything in it except for the power and usb.
if this doesn't work for you, unplug everything in your usb header except for octo.
hope this helps.
