• 09.01.2026, 22:43
knacker
Can Aquasuite control AIO & fans
Dienstag, 10. August 2021, 21:57
As the question states, does anyone know if Aquasuite can control an NZXT AIO pump and 5 noctua fans
Thanks
WinstonWoof
Dienstag, 10. August 2021, 22:33
depends on what you're using it with.
My only experience is with the Octo in which case it has 8 controllable PWM outputs
knacker
Mittwoch, 11. August 2021, 13:25
Ideally I would control all fans and the pump if possible in Aquasuite and let CAM control the rgb on the pump as NZXT confirmed it can only have 3 fans
knacker
Mittwoch, 11. August 2021, 16:24
I think I have sorted this as managed to get a controller from NZXT for her so will keep the good stuff for me :D
