• 14.02.2026, 23:09
Soft Sensor unit
Samstag, 18. September 2021, 18:00
Assigning a source to a Soft Sensor, and consequently removing the source, leaves the unit type from the removed source listed. (soft_sensor_units.jpg)
Remayz
Samstag, 18. September 2021, 18:20
i noticed that too when i got the flow sensor. the only way is to change the unit directly in aquasuite settings. But the virtual sensor should work too. Seems the application settings take priority anyway.
