• 04.02.2026, 09:27
mojmir
scripting with aquasuite?
Montag, 1. November 2021, 18:45
Hello,
i'd like to do some easy scripting, basically something like:
"at 10pm turn off all rgb"
is that possible somehow?
Many thanks,
Mojmir
Montag, 1. November 2021, 19:23
The easiest way to accomplish turning the RGB off at a certain time is to:
  • setup 2 profiles, one with RGB on & one off
  • then setup a Global Profile to switch profiles at a preset time (rgb_timed.jpg)
mojmir
Dienstag, 2. November 2021, 07:10
that's sufficient, thank you!
