• 14.02.2026, 23:12
xhamster
high flow LT connection cable
Freitag, 12. November 2021, 17:07
Cable failed after several months of use.
Nowhere to find expect here, And it's out of stock.
Considering make it by myself. Need some assistant about the wire order.
Since I'm using LT, no temperature sensor is involved. Can I just make it simple as three connector? In which order?
Thanks!
WinstonWoof
Samstag, 13. November 2021, 09:05
As its failed why not just cut the connecters off (leaving a short length at each end) and splice in new cable on a one to one basis using the colours(presuming its coloured) ?
