• 13.04.2026, 01:49
Top_Nurse
AquagraFX connections
Montag, 17. Januar 2022, 20:20
Greetings most exalted ones!
I just acquired a used 570 AquagraFX Type 2 factory installed (Point of View / TGT Tuned GTX 570 Beast) cooler. Is there any specific in and out connections? The connector appears to be made out of delrin with three socket head cap screws holding it on.
Remayz
Dienstag, 18. Januar 2022, 01:04
that ?
https://shop.aquacomputer.de/product_inf…roducts_id=2681
just standard G1/4 fittings to screw in the delrin block to connect your tubing. I can't say which is in and out, but it doesn't really matter.
