• 22.03.2026, 19:51
ToreDL87
No Aqua Computer USB Device Found
jeudi 17 mars 2022, 12:44
As the title implies, when I try to install software I get the said error.
I connected pump to MB like this:
https://www.computerbase.de/forum/attach…645-jpg.603843/
I need to slow pump down, its making way too much noise despite rubber dampening.
jeudi 17 mars 2022, 13:32
this dosent looks like an USB connector on your mainboard. disconnect the usb connector on your mainboard and compare with your manual.
jeudi 17 mars 2022, 16:11
It also looks like the USB connector is not fully seated into the mobo header on the right side, maybe because that is not a USB2.0 header. I agree this does not look like a USB2.0 header. What is the model of your motherboard?
jeudi 17 mars 2022, 19:03
The connection on the left is a 9-pin USB header.
Discussions similaires
