• 11.02.2026, 23:25
sonik00
Leakshild problem "solved it"
Dienstag, 12. April 2022, 15:23
I have a problem with the pressure, when I turn on the test, I say that I eat about 300+ but when I ship it is about 70-100, when I unscrewed the leakeshield and turned on the test, the working pressure of the image was beyond 350+ like something blocked or stuck if someone had such a problem how, please share, best regards.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »sonik00« (14. April 2022, 05:45)
sonik00
Mittwoch, 13. April 2022, 13:44
Hello, I was able to solve the problem with unstable pressure maintenance and slow pumping out of leakshield air, it was enough, a small change, the alarm does not go off and everything works stably. Regards
