• 30.12.2025, 03:46
knacker
Recommend fluid
Dienstag, 17. Mai 2022, 11:16
Any recommendations for fluid as I need to drain my loop and looking at fluid. Clear needed and hardline tubing with D5 next, leakshield and high flow next
Dienstag, 17. Mai 2022, 11:58
I have been using Double Protect Ultra for several years without issue, plus the high flow NEXT is calibrated to it.
Remayz
Dienstag, 17. Mai 2022, 16:26
Any clear coolant would work just fine but since you get a high flow next, definitely get DP ultra clear yes. easy tracking of your coolant condition :)
Tasky
Donnerstag, 19. Mai 2022, 02:44
Another vote for DP Ultra here, mainly for the D5 Next.
