• 11.04.2026, 08:04
BetterRed
Aquastream reporting 0 l/h from AC flowsensor
Samstag, 1. März 2008, 01:31
Er yeah, the title about sums it up. The aquastream ultra reports other measurements to Aquasuite, but no flow rate.
If I set the flowsensor to active the gui shows 0l/h from ---l/h. If aquasuite is closed and opened again the display again shows ---l/h and the flowsensor has been deactivated.
This seems really strange - both components are brand new and the aquasuite was downloaded about a week ago.
Re: Aquastream reporting 0 l/h from AC flowsensor
Samstag, 1. März 2008, 02:20
Have you saved your settings into the pump? Afterwards it's also necessary to restart the pump (off/on).
BetterRed
Samstag, 1. März 2008, 12:25
No I didn't. That's fixed it :). Thanks.
