• 16.04.2026, 21:45
dfmastin
USB? I have Leakshield, high flow NEXT, and OCTO
Freitag, 26. August 2022, 20:09
Do all three need their own USB motherboard header?
Freitag, 26. August 2022, 20:14
Yes. You can get a Hubby7 or similar internal USB2.0 hub that is SATA powered. That is what most people do.
Ytterbium
Freitag, 26. August 2022, 20:39
I had 2 USB 2.0 headers on my motherboard so 3 extra devices was fine.
dfmastin
Freitag, 26. August 2022, 21:25
thank you Ytterbium and Speedy!
ok, just making sure my thinking was correct
i do have two free usb 2.0 headers so i should be fine
just checking, i can plug two devices into a single usb header?
like on on the four row and the other on the five row?
Remayz
Freitag, 26. August 2022, 22:39
yep. each header has two USB ports.just get the connectors in the right orientation :p
