• 16.04.2026, 22:09
Caldorian
Putting ULTITUBE Pressure Membrane Lids on their sides while draining
Dienstag, 6. September 2022, 16:35
I've got both a Leakshield and the Multiport pressure membrane lid for my ULTITUBE. Is there any issues / risks of leaks through the lids if I roll my case onto its side to drain the loop? I'd obviously have the Leakshield powered off while doing so.
Hufeisen
Dienstag, 6. September 2022, 17:55
Please read the description on the Product Website in the Shop:
The membrane allows gases to pass and thereby continuously equalizes the internal pressure of the liquid cooling loop and the ambient pressure, while completely blocking coolant from leaking.
Caldorian
Dienstag, 6. September 2022, 23:22
Thanks. I know it says that, but there's a difference between blocking some gurgling fluid splashing up at the lid vs. the fluid being gravity pulled onto the membrane. Just curious how much "completely blocking" actually covers.
