• 05.04.2026, 14:10
SteinerSE
D5 Next Fan connector, PWM output?
Montag, 26. September 2022, 13:28
Hi!
Just want to quickly check, can you use the FAN connector on the D5 Next to output a RPM signal to the motherboard?
Remayz
Montag, 26. September 2022, 13:49
https://aquacomputer.de/handbuecher.html?file=tl_files/aquacomputer/downloads/manuals/D5_NEXT_english.pdf
It is either a fan controller or an input for a flow sensor (section 5.3).
