• 27.01.2026, 21:06
tiggerlator
Change from L/h to GPM
Sonntag, 6. November 2022, 20:23
I have a OCTO with a high flow LT connected to the sensor input. Aqua is showing L/H how do i change it to GPM?
thx
I7 12700k - Asus Rog Strix z690-A WiFi D4 - TEAM GROUP 2X16GB DDR4 3600C16 - MSI RTX 3080 GAMING X TRIO 10GB - Crucial P5 Pro 500GB M.2 NVMe Gen4x4 - WD SN850 1TB M.2 NVME Gen4x4 x2- SanDisk 2TB SSD PLUS 2.5" - Corsair RM850X - Lian Li o11D XL - EK 360mm PE - EK 360mm XE - EK supremacy classic - Generic (GPU) - Ultitube 150 D5 - dell s2721dgfa 27" nano IPS 165hz Custom corsair PSU cables
Remayz
Sonntag, 6. November 2022, 23:24
it's in the aquasuite settings. you have a little section for units choice for temperature, and flow
Montag, 7. November 2022, 08:04
This is working for the most things. Some input and calculations base on l/h as unit.
