• 10.02.2026, 22:08
MotoMazz
Flow signal problem - HighFlow NEXT -> OCTO
Donnerstag, 15. Dezember 2022, 13:15
I bought this cable:
https://shop.aquacomputer.de/product_inf…roducts_id=4046
... to be able to connect the "Signal" output on my HighFlow NEXT to my OCTO.
Problem is... the flow input on the OCTO says ~1900 L/H, while the HighFlow NEXT itself says 180 L/H.
What is wrong?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »MotoMazz« (15. Dezember 2022, 13:20)
/MotoMazz
Donnerstag, 15. Dezember 2022, 13:43
What is wrong?
You have to setup the Signal Output. (High flow next via USB and aquasuite)
MotoMazz
Donnerstag, 15. Dezember 2022, 14:11
Ok, thanks. I'll have a look.
I assume it's in the HighFlow NEXT pages in AquaSuite?
/MotoMazz
Donnerstag, 15. Dezember 2022, 14:19
Yes, in the Alarm and Signal Output configuration.
MotoMazz
Donnerstag, 15. Dezember 2022, 14:34
Thanks!
/MotoMazz
