• 23.02.2026, 01:11
Methodical
Aquasuite Software...why is it doing this?
Freitag, 13. Januar 2023, 18:11
When I open Aquaero fan settings tab in Aquasuite the settings tabs look weird. It's missing sliders, power settings etc and I can't make any adjustments. Can someone take a look at the photo and tell me what could be wrong and what I need to do to get the settings capabilities back? Is it bug'n out on me?
Thanks...Al
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Freitag, 13. Januar 2023, 22:49
Something is wrong with you device (Settings).
Reset your device to factory defaults and read first the manual from the download section.
https://aquacomputer.de/handbuecher.html
https://aquacomputer.de/handbuecher.html…o_6_english.pdf
Methodical
Sonntag, 15. Januar 2023, 02:31
Thanks. I will to the reset and see what happens.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Methodical« (15. Januar 2023, 02:33)
Methodical
Montag, 16. Januar 2023, 06:23
I had to do some cable management and had to remove and reinstall the USB cables and as a result Aquasuite is working fine now.
Thanks...Al
