• 07.02.2026, 22:57
somefatlady
setting up leak shield
Dienstag, 7. Februar 2023, 01:45
Took apart my water cooling loop and put it back together. Saw leak shield (standalone) had an update for the software and firmware. went to reset it up and now I see on the display screen step 8 code 2 with it flashing red. I cannot find any error codes on google.
Thanks
somefatlady
Samstag, 18. Februar 2023, 18:23
Bump
Sonntag, 19. Februar 2023, 03:37
Your best response will be from support@aqua-computer.de
