• 23.02.2026, 14:13
_wendigo_
bug in aquasuite X.66
Dienstag, 14. Februar 2023, 02:35
Id = {00000000-0000-0000-0000-000000000000}; ClientMachine = xxxxxxxxxxxxx; User = NT AUTHORITY\SYSTEM; ClientProcessId = 5364; Component = Unknown; Operation = Start IWbemServices::ExecQuery - root\cimv2 : SELECT * FROM Win32_PerfRawData_PerfDisk_PhysicalDisk Where Name LIKE "1%"; ResultCode = 0x80041032; PossibleCause = Unknown
when Aqua service is running with SSD/Harddisk enabled - it trickers this message in the eventlogs and causes WmiPrvSE.exe cpu load spikes.
from what i could read at some M$ site .... https://learn.microsoft.com/en-us/window…rectedfrom=MSDN
Maybe this should not be used anymore, instead use: https://learn.microsoft.com/en-us/window…rfinst-provider
Im not a programmer - but it would seem that there is a error from the select message... which looks like a SQL query error :) anyway - disabling the service monitoring for hard drives solves it....
_wendigo_
SORRY! x.64
Dienstag, 14. Februar 2023, 12:32
just realized that my system wasnt updated eventhough i though it was...
:-O Sorry ... i will of cause update it now, and hopefully it solves this issue i am seeing... i see there are "hardware monitoring" on the list of bug fixes, so that is pretty much spot on in this case.... so maybe thats a fix! :S
