• 04.03.2026, 21:35
zerophase
MPS 400 leaking.
Mittwoch, 22. Februar 2023, 04:41
I'm almost definitely out of the warranty for the MPS 400. I've noticed a very slow leak has formed around the screws. Tried tightening them and that did not help. Is there a custom o ring I can order for that part?
Methodical
Sonntag, 5. März 2023, 21:18
Use some silicone from the big box store or silicone used for fish tanks if you can't find parts.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Methodical« (9. März 2023, 16:04)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Sonntag, 5. März 2023, 22:29
The leak may be at the rubber boot around the two sensors prongs.
You may try to get a new boot from aquacomputer.
