• 25.01.2026, 10:26
Methodical
Aquasuite and Win11
Montag, 27. März 2023, 16:51
Does Aquasuite X and Windows 11 get along with each other?
I think I might update to Windows 11 but don't want to get surprised and have to become an IT specialists as I have too many other things to worry about.
Thanks...
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Montag, 27. März 2023, 18:06
I'm testing Wimdows 11 in the insider program since it's available, so far I haven't found a reason to switch completely to Windows 11, I'll probably stay with Windows 10 until 2025.
Beyond that, I haven't found any problems with the Aquasuite.
Methodical
Montag, 27. März 2023, 21:29
Interesting you say that about Windows 11 because I have cold feed. I know there was an issue downloading Bitdefender on my daughter's Windows 11 laptop and I don't what that headache. Hopefully it's a thing of the past now.
Thanks for the feedback...
Remayz
Montag, 27. März 2023, 21:55
it should work just fine.
You'll always have people saying "hey i'm on windows 10/11 and it keeps bugging like this and that" but the thing is developped for those OS. if you encounter any issue, there's support.
For windows i usually wait 6 - 8 months after release to have the early bugs ironed out then it's smooth sailing. the 11 thing came out late 2021...
The good thing with Aquasuite is if there's a glaring bug discovered, it gets fixed very quickly.
But like Taubenhaucher, i never had any issue on windows 10 nor 11 so far
Dienstag, 28. März 2023, 07:57
https://www.av-test.org/en/
Meanwhile, there are few reasons to choose an anti-virus solution other than Microsoft defender, as AV Test's long-term tests show, and virus scanners have always caused problems, sometimes one, sometimes another.
I use on 4 of my 5 computers, Defender and on my main computer F-Secure, only on my main computer I have a problem with a certain software that cannot establish a secure connection as long as I have F-Secure installed, with Defender this problem does not appear.
