• 28.04.2024, 19:44
New User to AquaComputer / AquaSuite Ecosystem - Advice and Suggestions Welcome
Mittwoch, 10. Mai 2023, 00:50
Hi everyone,
I've recently converted my build from Corsair's Hydro X ecosystem over to AquaSuite with the following components:
  • Ultitube 200
  • D5 Next Pump
  • Leakshield
  • Octo
I've also changed my fans to Lian Li's Infinity Uni Fans, with their hub plugged into fan slot 1 on the Octo's PWM header.
It all functions and everything is showing up in Aquasuite so I'm relieved I've got it all set up but I feel like I'm barely scratching the surface. I've got the following questions as some things are confusing (from hardware and software):
  • Would I benefit from adding in a High Flow NEXT sensor and would it compatible with the D5 pump?
  • As mentioned, I have the Lian Li Uni Fans connected to the Octo. Aqausuite does detect them but I can't get Aquasuite to control them. I turn on 'MB RPM Sync' in L-Connect but it doesn't seem to make any difference. Aplogies if this is a noob issue but if anyone can walk me through how to get Aquasuite to control them I'd be grateful.
Thanks in advance.
