• 26.04.2024, 23:39
klara
Question about high flow LT cable
Dienstag, 16. Mai 2023, 07:40
I've just received my high flow LT and I notices that the connection cable have multiple interfaces.
For flow sensor, there are two connector: one is for aquacomputer products, and the other one is common fan header to monitor flow rate using RPM. It's good.
However, there's another interfaces, temperature. As far as I know LT version does not have temperature sensor.
Is this just because LT shares same cable with high flow 2 which includes temperature sensor?
May I remove those cables for temperature sensor?
