• 27.01.2026, 01:30
Top_Nurse
Bonding small magnets to rubber?
Donnerstag, 10. August 2023, 17:23
I've decided that the best way to put my Hubby7 and Splitty9 to the case is to bond small magnets to the rubber housing. If anyone has done this what adhesive did you use?
Donnerstag, 10. August 2023, 20:24
THIS may be an option... no experience with it though
Freitag, 11. August 2023, 02:54
You may want to consider magnetic standoffs. HERE is a thread you may want to check out. These are available on Amazon. Here are a few examples.
Exmaple 1
Example 2
Example 3
Top_Nurse
Samstag, 12. August 2023, 15:40
Thanks to InfoSeeker and Speedy-IV for the suggestions. I think I will first try the magnetic standoffs and if that doesn't work I will try Loctite. :thumbsup:
mditsch
Samstag, 12. August 2023, 16:37
Exmaple 1
Example 2
Example 3
:thumbsup: :thumbsup: :thumbsup:
