• 28.04.2024, 09:40
robbiec
Need some advice on hardline tubing conversion
Montag, 4. September 2023, 11:52
Hi All,
Hope you're all keeping well. Looking for some advice / opinions on fittings / hardline piping please. I'm currently running a near enough all AquaComputer cooling setup with Bitspower fittings and 10/16 tubing.
So Resevoir / Pump / Leakshield | 1st Rad | GPU | CPU | 2nd Rad and back to res
All nice and easy and to be fair has worked well for the last 15 months or so. I plan to add in a Flow sensor high flow NEXT as the semi virtual flow sensor in the D5 is not massively accurate.
So who makes the best hardline piping that does not discolour after a couple of months?, who makes the best fittings? and any recomendations for a pipe bending / trimming kit? :)
Thanks v much.
Amd Ryzen R9 5950X | Asus Crosshair Viii | AMD RX6800 | 32GB B-Die 3600 C15 | 2 x Samsung 970 Evo Plus 2TB | 2 x Addlink S70 1TB | 2 x Toshiba X300 4TB | Aquacomputer: Cuplex Kyros Vision Vario PVD - D5 Next - Ultitube 150 - Airplex Radical 360/2 x 2 - Splitty4 - Hubby7 - Leakshield - Some RGBx | Seasonic Prime Gold 1000W | Lian-Li 011 Evo | 6 x Noctua AF12 PPC | LG 27GN88A-B | Oculus Rift S | Graham Slee Bitzie DAC
