• 10.05.2024, 09:25
airplex radical 2/360
Donnerstag, 14. September 2023, 08:14
Can anyone tell me if an airplex radical 2/360 with aluminum fins will properly cool off an AMD 5600X, sterling silver Cuplex XT, XFX RX 7900 XT reference with an Alphacool cooler? Using an Ultitube D5 150 Pro Next pump with 8mm x 6mm tubing. I also bought an airplex radical 2/240 to put in the top if necessary, but my Seasonic Q704 case is getting pretty busy with just the 360 in the front.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Top_Nurse« (14. September 2023, 08:25)
