• 28.04.2024, 07:53
Aquabus fried?
Montag, 4. März 2024, 03:48
Hi, So I have an Aquaero 6 XT and 3 flow sensors (1 mps400 and 2 High Flow USB's) that aquabus no longer works on.
I am not sure what has happened to them but no matter how many times I check for Aquabus devices they will not show up.
These all used to work then one day just stopped.
All devices have been configured with USB first and then I have tried multiple 3 and 4 pin cables without any luck.
Tonight I used my multimeter to test the aquabus pins on all 3 flow sensors and my Aquaero and all showed lower readings than what is suggested to be the norm of 1.9, mine were anywhere from 0.98 to .060.
Am I just out of luck and have to buy all new devices or can these be repaired?
I really just want to be able to see my High Flow USB on the actual Aquaero display on the 6xt but it seems that is not possible that I have found without aquabus functioning.
