• 11.06.2024, 14:55
Just updated to version X77, sensors on high-flow next not connecting to Octo?
Mittwoch, 1. Mai 2024, 19:09
Hi, have a Highflow Next and Octo - before the recent software version upgrade (I should've paid a bit more attention to this), I used the water temp setting from the HighFlow to control the fan curves on my Octo. After the upgrade, they seem to no longer talk to each other. I tried removing and re-adding the sensor, and while the temperature setting updates properly in Aqua under the HighFlow tab (see top picture), when I add it as a sensor to the Octo, it doesn't show up there.
Any thoughts on what I might be missing here?
»bjcsoln« hat folgendes Bild angehängt:
