• 04.04.2026, 22:54
a_movingtarget
Output to "sleep" D5 Next and Fans when PC sleeps (External Power source)
Sonntag, 9. Juni 2024, 18:30
Hello! I'm running a D5 Next on an external radiator with SATA via external power brick and connected to my PC via USB-A (for aquasuite). Is it possible to have Aquasuite sleep my pump / fans on the external when the PC goes to sleep as well? I tend to forget to unplug the pump when I leave for whatever other distractions come my way... Thanks in advance!
Montag, 10. Juni 2024, 11:35
No, it is not possible to stop the pump.
You may be able to switch off your external power supply unit via the master slave socket.
