• 23.02.2026, 05:26
PetrovichOriginal
Aquasuite x.59 doesn't see the CPU's data
Mittwoch, 7. August 2024, 11:10
I am using aquacomputer cuplex kryos next with vision and I want the display to show the CPU temperature. But aquasuite does not display processor data. All others (motherboard, RAM, HDD) are displayed correctly. Why is this happening?
»PetrovichOriginal« hat folgendes Bild angehängt:
PetrovichOriginal
Mittwoch, 7. August 2024, 11:12
My hardware: Gigabyte B650M Aorus PRO AX + Ryzen 7800 x3d
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »PetrovichOriginal« (7. August 2024, 11:18)
Mittwoch, 7. August 2024, 11:24
your aquasuite version is too old.
release date: aquasuite X.59 (28.09.2022)
cpu: 7800x3d -> release 2023
https://licensing.aquacomputer.de/shop/aquasuite
PetrovichOriginal
Mittwoch, 7. August 2024, 11:51
I updated the version to x.79. No result
Mittwoch, 7. August 2024, 12:08
This looks like an error when installing the drivers for monitoring.
Check whether your virus scanner is blocking anything.
Known problems are: BitDefender, Avast, Avira
PetrovichOriginal
Mittwoch, 7. August 2024, 12:11
I just installed an operating system on a new computer. There are no viruses and AIDA sees the CPU temperature
PetrovichOriginal
Mittwoch, 7. August 2024, 13:03
how to get a refund of 9.90 euros for a non-working version?
Mittwoch, 7. August 2024, 13:07
Check Windows Defender or your Anti Virus Software.
It is a know issue as a false positive detection from our Monitoring Driver.
PetrovichOriginal
Mittwoch, 7. August 2024, 13:24
What exactly should I check in the Windows Defender?
PetrovichOriginal
Mittwoch, 7. August 2024, 14:03
You didn't answer me, how to get a refund of 9.90 euros for a non-working version? Your advice did not help me solve the problem and I wasted my money
Donnerstag, 8. August 2024, 07:21
you have to write a mail to info@aqua-computer.de
the problem is not the aquasuite. the problem is somewhere in your WIndows configuration.
