• 05.03.2026, 02:46
spinelli
Deaerate Pressure OK?
Dienstag, 24. September 2024, 05:31
AquaSuite states required negative pressure as 300 m/bar for deaeration.
Every time I do the test, the negative pressure keeps building but as soon as it reaches 300, it immediately goes down to around 270 and then continues the deaeration cycle while at around 265-270 instead of 300. When the cycle is completed, the same process starts over.
Is this correct behavior? Is it supposed to do the test at 270-ish m/bar, not 300?
Picture is attached.
»spinelli« hat folgende Datei angehängt:
  • ghjghjhgghj.JPG (56,88 kB - 78 mal heruntergeladen - zuletzt: 26. Februar 2026, 13:34)
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »spinelli« (24. September 2024, 05:41)
Dienstag, 24. September 2024, 07:15
this is the normal behavior.
