• 01.01.2026, 07:41
J-MI
Leakshield configuration
Mittwoch, 16. Oktober 2024, 00:19
Hello everyone.
I thought the aquasuite had priority over the leakshield configuration. However I noticed that if I choose the shield option on the software but the leakshield (cover) is set to another function (release for example or monitoring), it is always this function that is activated at computer startup and not the leakshield configuration determined in the aquasuite profile.
Is there a particular setting I've missed, so that it's the configuration saved in the aquasuite that controls the lid configuration when the computer starts up?
Thanks
softlion2
Dienstag, 5. November 2024, 12:17
It looks like it's your last action that decides what state it is on. For example Aquasuite should synchronize to whatever state the linkshield has been manually switched to.
