• 11.01.2026, 07:19
anub1s21
Double Protect Ultra maintentance question
Donnerstag, 5. Dezember 2024, 19:41
this might be a odd question but i've got a high flow NEXT and i started to use DP Ultra just over 2 years ago.
now the high flow NEXT is telling me everything is a oke, 100% water quality conductivity is at 11.6 whatever that unit is.
i used to just do maintenance every year but then also made minor tweaks but for the past 2 years i've been content with my loop so i've been lazy and have not performed any maintenance (other then some dust busting) so i'm suprised everything seems good.is there anything i should probably be topping it up with? (growth/corrosion inhibiter) i mean i should probably just flush it and refresh it but i'm tempted to just let it run and see :P
mditsch
Freitag, 6. Dezember 2024, 04:05
Hi anub1s21,
when you'e HFN is saying, that everything is fine you can trust it. 2 years is for DP Ultra like yesterday for you.. :)
