• 25.05.2026, 10:42
aveamurechi
One of the D5 pumps takes significantly more current (and power) than the other
Samstag, 28. Dezember 2024, 21:27
I have a dual pump setup, using the dual pump mounting piece from Aquacomputer.
Both pumps are setup the same way in aquasuite, (curve controller, based on water temp).
Yet I see that one of the pumps for the same RPM takes about double the current and double the power. Any idea why that may be?
I attached screenshots.
»aveamurechi« hat folgende Bilder angehängt:
Freitag, 3. Januar 2025, 08:24
Hello,
you can swap the controllers of both pumps.
The value of 2.4W sounds rather implausible to me.
If it's not the controller, swap the pumps in the top.
