• 15.05.2026, 10:31
david.berkman
When I switch Aquasuite global profiles, my D5 Next pumps lose their ...
Donnerstag, 6. Februar 2025, 05:49
When I switch Aquasuite global profiles, my D5 Next pumps lose their curves (automatic, with min/max settings) and revert to 100% constant power. This does not happen with the Octo and its fan curves (also automatic with min/max settings), which stay. What am I missing?
Thanks
Freitag, 7. Februar 2025, 08:56
Create new profiles in the pump tab and test the profiles individually. Click on each individual profile and check whether it is loaded correctly.
If everything works, you can link the profiles to the Aquasuite profile management.
