• 04.01.2026, 04:52
Ed.Dark
Aquaero Lt5 and atx power break / relay
Montag, 17. März 2025, 13:49
Hi, I emailed aquacomputer but I don't know if they do email support now.
Could someone help me with this please?
I have an Aquaero LT5 and an aquaero power connect. The standby power connector is providing 5v to the standby header on the device and I have a USB connection to the motherboard.
All is working well except the power break. Simply put, the LT5 is not behaving as suggested in the manual!
"If alarm actions or timer actions are configured regarding the relay output, the current relay state is permanently overwritten once a relay action is triggered. From this point on, the relay state can no longer be changed by a controller. A complete power cycle (including USB and standby power) is required to have the relay operated by a controller again."
I can prove repeatedly that this does not behave this way. If I activate the relay (I have a slider setup to emulate a temp sensor
