• 08.05.2026, 12:14
Dav'
High flow USB 53129 connection loss in AIDA64
Sonntag, 8. Juni 2025, 22:04
Hi !
I've got an issue with my MPS: it looses connection randomly, up to several times per minute, with AIDA64. It impacts temp and flow.
Considering my Aquaero et my Quadro don't have this issue, I guess it comes from the MPS.
Problem is, when AIDA looses the MPS it mess up every other temperature sensor.
It's been a while I've got this issue but now I'm using aquabus, which did not resolve the lossses, and have a lot of sensors it becomes really annoying.
Please note I asked AIDA dev and of course answer was "not related to AIDA but to your MPS".
Is there a way to disable the internal MPS temp sensor ? I don't need it anymore plus it gives wrong values (compared to the 4 other temp sensors in the loop).
Thanks for your help !
